TIE BAR RODS HEAVY DUTY ADJUSTABLE KIT (USE C-STR627 BUSHES)
Minispares räägib nende kohta järgmist:
"Pair of adjustable Tie-rods-see 21A1092 tie bar kit When you change the length of the lower control arm to attain the desired degree of camber, the caster also changes. To reset it you must ba able to change the length of the tie-rods. Our special adjustable tie rods are almost twice the diameter of the stock version and are far less likely to bend. Remember, in addtition to controlling caster, these tie-rods also control stability under braking! Our own brand have a hexagonal cut on the rod for easy adjustment. Do not use harder bushes on both sides as no advantage is gained. Hard on the outside and soft on the inside. use kit C-STR627"
see pukside komplekt maksab 3,5 naela ja see on nii kerge, et võib ka postiga saata.
mina ostsin nad £ 26,32 x 1,14 x 15,65 = 469 EEK eest ning nüüd müün ta ära täpselt 500 eek eest - transpordiraha ka hinna sees. Niisiis, kes tahab omale täiesti tutikat TIE BAR RODS (ei tea kuidas eesti keeles) komplekti, mis on tugevam kui tavaline, mis on regullitav ja mis kõlbab ka sportimiseks, siis andke märku!
